Good day All,
I am having difficulties getting the latest version (3.0) of the PDF Extension on an Ubuntu 14.04 server, although I have also come across this error on a Windows 10 localhost deployment.
I have run the command (sudo apt-get install libgtk2.0 libxtst6 libxslt1.1 fonts-freefont-ttf libwebkit2gtk-3.0-25) as desrcibed in the documentation for a Ubuntu 14.04 deployment.
I get the error: "Element not found or does not exist. For documentation on this error, please visit: http://seleniumhq.org/exceptions/no_such_element.html Build info: version: '2.52.0', revision: '4c2593cfc3689a7fcd7be52549167e5ccc93ad28', time: '2016-02-11 11:22:43' System info: host: 'localhost', ip: '127.0.0.1', os.name: 'Linux', os.arch: 'amd64', os.version: '4.14.40-elastic-test', java.version: '1.8.0_131' Driver info: driver.version: unknown"
Has anyone come across this error before and have some advice on a fix?
@VladimirRosu do you have some insight possibly?
Hi @jbester.
Unfortunately, the marketplace extension you are using is not compatible with ThingWorx 8.3 and above. This and other extensions on the marketplace are currently under review for future update or removal.
Please refer to the ThingWorx Extension Development guide for writing your own extension.
Regards.
--Sharon
Hi @jbester.
Regards.
--Sharon
