Hello. i am using a pareto chart to combine same X-axis values (reason), but for some reason it is stacking other values.
please help.
Hi @LP_10027711
You may want to take a look at the Schedule chart. If that doesn't solve your issue, please provide more details around your use case. Also, what version of ThingWorx are you running?
--Sharon
Hi @LP_10027711
--Sharon
I had to recreate my infotable that feeds the Pareto Chart to make it look the way i wanted. thank you!
