Pass Parameters from Master to Children
PF_9427478
i have a Master Mashup and want to pass parameters to the Mashup which is using my Master.
So i set the State in my Master to, for example "Running", then my Mashup should update content accordingly. I just need the value i set on my Master Mashup somehow in the other Mashups that are using it.
Is this possibly via Mashup Properties? Or how can i do this?
Url Params came to my mind, but arent the best solution, because it is just a filter.
Cheers Pat
As PaiChung mentioned earlier you can use mashup parameters. You can also achieve it by using session variables. Hope this helps you.
PaiChung
22-Sapphire I
(To:PF_9427478)
You should be able to use Mashup parameters I believe.
Even though a master is specified from the mashup, you can add the mashup to the master and create the binding from your master to the mashup parameters.
PF_9427478
(To:abhiramk)
Session Variables did the trick!
Thanks for helping!
