Hello ,
I am looking for the location where i can locate the license trust of thingworx .I am able to delete the folder ptc_p but as i can remember there were other files that need to be removed.
Any help would be appreciated
Hello @AM_10639709
A typical path is C:\Windows\System32.
However you can check by typing:Type “echo %SYSTEMROOT%" at the command prompt and press “Enter.” The result of this search is the root folder for Microsoft Windows.
Do share if you have any further questions.
Bhawna
Hello @AM_10639709 ,
These files can be located at one of the following paths:
%systemroot%\System32\config\systemprofile
%systemroot%\ServiceProfiles\LocalService
%systemroot%\ServiceProfiles\NetworkServiceC:\Users\<username>
C:\Users\<username>
Pls let me know if you are still not able to find the files.
Bhawna
Hello @bchaudhary
Thanks for your prompt response .
What does systemroot means here where can i locate it?
Hello @AM_10639709
Bhawna
