1. Do we have any option to adjust popup size?
2. What is the difference between popup and modal popup?
Modal Popup (and I think the tooltip will tell you, will keep the popup on top and block access to anything underneath until the popup is closed.
I believe in the Navigate function there is a sizing for the popup?
Hi @AP_9587236
If the previous response answered your questions, please mark it as the Accepted Solution for the benefit of others with the same questions.
Regards.
--Sharon
