Post sessions from field devices remain active
Glad the appKey works. That is exactly what its use case is. Also these calls are not meant to be in browser.
We are making an HTML/Javascript SPA website that needs to access ThingWorx services via the REST API calls. This is a very simple website that we hope requires no server-side (PHP) code.
I am testing the API calls in PostMan (Browser-based) and the only way I am able to successfully make a call is if I create a session. Is there no way to make a Javascript/Browser-based API call to a ThingWorx platform server without creating a session??
-Matt
Are you using an appKey?
What we've noticed is that when using a REST API tool that does browser based type calls, you will fail auth every other call even when using the appKey.
This doesn't apply when you are using a 'true' rest call.
This is something on the bug list to be fixed.
