PostJSON and PutJSON in ThingWorx 9.2
RK_0705
How to use these two services of contentloaderfunctions.
We need to pass body as json for getting the response.
Please share the examples of both services especially PUT.
Thanks in advance.
I don't have an example of PUT but it should be very similar to the Post Example.  For context the example below is making a post request to get an application TOKEN back and setting some thing properties.
try
	let content = {
		"Username": me.username,
		"Password": me.password
	var response = Resources["ContentLoaderFunctions"].PostJSON({
		ignoreSSLErrors: true,
		url: me.baseURL + me.tokenEndpoint /* STRING */ ,
		content: content,
		contentType: "application/json"
	var now = new Date();
	if (response.body.token && response.body.token != "") {
		me.token = response.body.token;
		me.lastSuccessfulAPICall = now;
		me.tokenExpirationDate = dateAddHours(now, me.tokenLifetimeHours);
		result = true;
catch (err) {
	logger.error(me.name + ", error in GetToken service: " + err);
Travis
VladimirN
24-Ruby II
(To:RK_0705)
Here are some helpful materials:
"REST API Overview and Examples": https://community.ptc.com/t5/IoT-Tech-Tips/REST-API-Overview-and-Examples/td-p/534777
"How to call the RESTful API in a ThingWorx platform service": https://www.ptc.com/en/support/article/CS237875
"ThingWorx: Difference between GET, POST, and PUT REST methods": https://www.ptc.com/en/support/article/CS214689
"How to Post XML or JSON Content to a Custom Thingworx Service via REST API": https://www.ptc.com/en/support/article/CS201979
"ThingWorx: Post JSON to a service that accepts JSON as an input parameter": https://www.ptc.com/en/support/article/CS213601
Hi @RK_0705 ,
Try something like this:
var headers = {
	"header1": me.header1,
	"header1": me.header2
var body= {
	"param1": me.param1,
	"param2": me.param2
var directURL = "<Your_Endpoint_URL>";
// It returns JSON
var result = Resources["ContentLoaderFunctions"].PostJSON({
	url: directURL /* STRING */,
	content: body /* JSON */,
	headers: headers /* JSON */,
	useProxy: true /* BOOLEAN */,
Note: I created header and body parameters as a Thing properties, but you can pass them as a service parameters too. Hope this helps.
Shirish
