Print_MashupPage_Thingworx
AK_10547708
3-Newcomer
I have used the Print Extension widget to take to print of mashup from runtime.
I want to give custom background color to my print page.
Any suggestion, how can i achieve that?
Thanks in advance!
Hi @AK_10547708
Look at the below article, and let me know your output.
https://www.ptc.com/en/support/article/CS319138
Hello @AK_10547708
Pls check the community post for your reference:
https://community.ptc.com/t5/ThingWorx-Developers/Printing-a-Mashup-on-runtime/m-p/962830#M67261
Bhawna
Hi @AK_10547708 ,
PTC does not provide any supported Print Extension widget. Can you tell us where did you get that widget from and how it works?
I'm personally not sure how that widget works in order to offer an advice for how to change the background color.
From a ThingWorx perspective you can always change the Mashup's Style that contains the background color (and change the underlying container's background color to none), but I'm assuming you already tried that and it does not work, right?
