Hi, I am trying to use your widget. It would be really cool, but it does not fully work for me..
From some reason it cannot print root-Mashup. It shows the blank page. If I put my graphs inside of a panel, it rearrange them thus making graphs visible only partly. Any ideas how to print several widgets at the time and avoid the re-arrangement.
Tomas
Even i am facing same problem can anyone resolve this issue please let us know
Did you copied the correct name as hyun gu kim's instructions?
hi hyunkook
i am Actually facing the same issue, any idea how to fix that? the button is working great but it's rearranging everything would be perfect if we can fix that
thank you
Hello;
I just tried the window.print() function but i cant use "window" keyword. So i use print() function in expression and trigger it with a button and it worked. I want to share if anybody need to quick fix about this issue.
do you mind uploading your zip file ?
I did not try or used PrintButton extention itself.
I just want to print a popup mashup and with basic logic, created expression in mashup with JavaScript code "print()" witch trigger with a button. Which is open browser's print dialog. And then i configure the zoom, margin ect. It worked for me.
I also did read disabling browser's print dialog which in chome can be done from chrome://flags but i havent try yet.
Hi Guys
well the problem is that the <div>s from html at runtime don't have a specified Position and by default position is set to Static which in return ignores the padding and the position properties of the wedgits
just add an inline style to <div> with a position:relative at runtime.js and it should work fine for charts and images
win.document.write('div {position: relative;}');
hope it helps
Could you suggest where we have to add the below line.
I have added above code in below function which was PrintButton Extention code
var printfind = function(){
win = window.open();
self.focus();
win.document.open();
win.document.write('<'+'html'+'><'+'head'+'><'+'style'+'>');
win.document.write('body, td { font-family: Verdana; font-size: 10pt;}');
win.document.write('<'+'/'+'style'+'><'+'/'+'head'+'><'+'body'+'>');
var url = thisWidget.getProperty('UnitName');
var b = document.getElementsByTagName('div'); // binds "b" to the desired element.
TW.log.info(url);
//var div = document.getElementById('divID');
for (var i=0;i<b.length;i++){
if( b.item(i).id.indexOf(url) > -1)
win.document.write(document.getElementById(b.item(i).id).innerHTML);
break;
win.document.write('<'+'/'+'body'+'><'+'/'+'html'+'>');
win.document.close();
win.print();
win.close();
After changes, import was not successful. Could you please where we can include code ?.
Thank you
