Hi this is peter
How can i get printer data's in Thingworx using KEPServerEx.
Hi @Peter_Raj.
This article from our knowledge base may be helpful.
If you are running into issues, we will need the following:
Regards.
--Sharon
Hi @Peter_Raj.
Regards.
--Sharon
Hi @Peter_Raj.
If the previous response helped to find an answer to your question, please mark it as the Accepted Solution for the benefit of others on the community with the same question.
Regards.
--Sharon
