Problem When Applying the Create Application UI- Cannot see the OpenStreetMap on Design Tab
Beyza
3-Newcomer
Hi there,
I'm trying to apply tutorials for thingworx. But I stucked at first step. When I try to select OpenStreetMap from design, I cannot see it in my trial account. That's why I cannot move forward.
Cheers.
Beyza
When the Open Street Map widget was removed from the marketplace, the guide screenshots and instructions were updated to use the Grid Advanced widget. References to "map" in the guide should read "Grid advanced" and will be corrected in the publicly available guide.
Instructions for displaying data on a map are available in the "Display Geolocation Data Using Google Maps" guide:
https://developer.thingworx.com/en/resources/guides/google-map-widget-how
cmorfin
(To:Beyza)
@Beyza
Could you please send a link to the tutorial you are following ?
The OpenStreetMap extension has been removed from Market Place, This post may be helpful, but I'd really like to have the exact tutorial url you use.
Christophe
Beyza
3-Newcomer
(To:cmorfin)
slangley
(To:Beyza)
Hi @Beyza.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others on the community.
--Sharon
