Problem with guide "Create an extension"
MD_10263895
https://developer.thingworx.com/en/resources/guides/eclipse-plugin-thingworx-extension-development-t...
I have problem, i cant download Eclipse plugin and SDK.
I get this error:
5 REPLIES 5
Hello @MD_10263895 ,
pls find the attached article for your refrence:
https://www.ptc.com/en/support/article/cs233537
https://www.ptc.com/en/support/article/cs201191
Kindly revert back if issue persists.
Regards
Bhawna
How can i get cutomer id? I haven't customer id.
Are you not able to access the article?
Try using with the same that you are using for logging into community .
Regards
Bhawna
I am able to access the article, but when I try to download SDK or Eclipse plugin i get error - "Customer Number   is invalid."
Hello @MD_10263895
I assume your account is not the Customer account. In that case, I would think you just need to contact support to get your number associated to your account.
Regards
Bhawna
