Probleme with Upgrade from 7.3 to 7.4.7
pjoly
11-Garnet
Hello
I'm trying to upgrade from 7.3 to 7.4.7 (MED-61111-CD-074_SP7_ThingWorx-Platform-Postgres-7-4-7.zip) on Ubuntu using postgres
I have followed the document Upgrading to ThingWorx 7.4  and the chapter  "In-place Upgrade to ThingWorx 7.4 (Neo4j/PostgreSQL/MS SQL Server/H2) on Ubuntu"
Unfortunately I cannot connect anymore to the Composer, the Browser says "ERR_CONNECTION_REFUSED"
I even reboot the server without sucess
I have this error in catalina.out
03-Jan-2018 17:51:38.572 SEVERE [main] org.apache.coyote.AbstractProtocol.init Failed to initialize end point associated with ProtocolHandler ["http-nio-80"]
java.net.BindException: Address already in use
I'm using https to connect to the Composer
Something changed between 7.3 to 7.4 or something to reconfigure when upgrading ?
Pascal
pjoly
11-Garnet
(To:pjoly)
To complete
If I restore the Thingworx.war from 7.3 and restart tomcat8 evrything works again
so the issue seems for me in the Thingworx.war in 7.4.7
Regards
sbalta
(To:pjoly)
Hello pjoly​,
Regarding the error that you mentioned, could you please check this article: Article Viewer | PTC
pjoly
11-Garnet
(To:sbalta)
hello
  • This error means that the Apache Tomcat port is already in use
  • Either the port number needs to be changed to an open port or the application blocking the configured Tomcat port must be shutdown to release the port
I read this article but I did not change the ports between 7.3 and 7.4 and I did  not add any new applications when I start the 7.4.
I do the 2 tests on the same server, just replacing  one file "thingworx.war" for 7.3 and 7.4
it works fine with 7.3 and I have this error in 7.4 ?
What is different for 7.4 for this tomcat port ?
Regards
Pascal
sbalta
(To:pjoly)
Hello Pascal,
I would like to have a remote session with you on the ticket that you have with the TS Support team ****4373.
Could you reply in that TS case, so we can synchronaze on a convenient time frame?
Thank you!
