Procedure for adding Apps (custom Mashup) to the Navigate Landing Page
srinivasak
6-Contributor
Hello All,
I am new user to the ThingWorx extensions and customization. I have created a new App for collecting incomplete workitems from Windchill. The requirement now, is to add this App to the list of default PTC Navigate Apps.
I tried to follow the below link, but there is some initial steps (extension setup / how to start the process of creating extensions).
http://support.ptc.com/help/navigate/13/en/index.html#page/PTC_Navigate/Nav_CustomizeAddLandingPageApp.html
Any help related to the procedure for adding newly developed App to the landing page is highly appreciated.
Thanks in advance for your help!
CRArko
(To:srinivasak)
Hello, Srinivasa Kompella.
Are you using Navigate 1.3 as indicated by the link you reference or a later version?
Also, you may want to check out the Expert Sessions for ThingWorx Navigate at this location:
https://support.ptc.com/appserver/cs/portal/thingworx/csm.jsp?p=2
-- Craig A.
srinivasak
6-Contributor
(To:CRArko)
Hello Craig,
The Navigate is at version 1.3.0.
PS: I couldn't open the link you shared. May be, an access issue.
Can you please share a PDF or some other documents I can refer?
CRArko
(To:srinivasak)
Hello, Srinivasa.
Let me confirm this with our Navigate team, but if I recall it may be Navigate version 1.5 or later is required to accomplish this.
-- Craig A.
