Is there a way to do that? I have only found the services to set REMOTE bindings as is explained in this links: http://support.ptc.com/help//thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Composer/Things/ThingProperties/ProgrammaticallyAddingPropertiestoThings.html
https://www.ptc.com/en/support/article/CS233812
I am using Thingworx 8.5
Hi @MD_10146790.
Did you find the service SetLocalPropertyBinding? You will need to run the AddPropertyDefinition service first to create the property.
Regards.
--Sharon
There is no option for LOCAL binding. Only Remote or NO binding
Hi @MD_10146790.
Regards.
--Sharon
