Hi Team,
I tried to import the attached progress gauge extension (took from one of the community post) but it's not working for me. I am seeing below error in Application Log.
@Krish007 : I checked the extension attached here and it does not have a metatdata.xml file. I think you have taken from this post: https://community.ptc.com/t5/ThingWorx-Developers/Progress-gauge-import-failed-in-Thingworx-9-1/td-p/706522
Instead, can you please try downloading 'Progressgauge1.zip' extension from this post and import?
Hi @Krish007
If the previous post helped to resolve your issue, please mark it as the Accepted Solution for the benefit of others with the same issue.
--Sharon
