Hi All,
I was trying to import the Progress gauge in the Thingworx platform 9.1 with postgres as Persistence provider. I am getting below error
The extension 'ProgressGauge_ExtensionPackage' version [2.0] must match the "major.minor.patch" pattern containing only integer values. Assuming a zero value for patch number. Please fix this in the metadata.xml file of the extension.
I read couple of articles, which tells to update version in metadata XML. I am not sure which version. Any help on this will be appreciated. I am attaching the ZIP I got from the marketplace.
Swaraj
Hello @SO_9699370 ,
I have updated the xml file inside the extension.
Can you give a try and see if you can import it ?
Hope it helps,
Hello @SO_9699370 ,
Hope it helps,
Thanks it worked.
