Is there any way to show the remaining gauge value in some other colors or some borders
Ex:
The value in the image is 45
Total value will be 100
Remaining 55 should be shown in other color or from 45 to 100 only gauge border should appear.
Will be of great help, if anyone supports..
Hello @Sathya
I could find following posts that might be helpful for your use case here
How-to-create-a-half-progress-gauge-using-the-standard-gauge
Progress-Gauge-State-formatting
Om
Hello @Sathya
Om
you can also use two progress gauge one above the other with different z index. One progress gauge will show actual data and another with different color with by default 100 percent data. this will also suffice your requirement.
Suraj Patil
