Property Table is picky about the data source
rtaylor-3
Greetings,
Seems as though the Property Table widget is picky about the data source.
I couldn't get it to display any data until i used the PTC.Asset.AssetPropertyValue DataShape.
Apparently it requires the baseType column for formatting.
Maybe i just missed some documentation somewhere.
Just an FYI for others having similar problems.
Hi Robert,
How did you use the PTC.Asset.AssetPropertyValue DataShape ?
I created an InfoTable backed by the PTC.Asset.AssetPropertyValue DataShape, populated it with data and returned it from my service which was bound to the widget.
jkaczynski
(To:rtaylor-3)
Hello Robert Taylor​,
Basically, the Property widget should work correctly with any service, that returns InfoTable with DataShape specified.
so you can create other service, that has other DataShape set.
J.
