Dears,
I set up remote property on thingworx, but quality of tag is inconsistent on thingworx and kepware.
I am so confused with this inconsistancy, could anyone tell me which quality is correct?
Hi @LeoChen ,
If you change the startType to "useDefaultValue" does this behavior change?
Otherwise probably some of my Kepware colleagues might be able to chime in (I do believe it would be wise to open a support case in parallel anyway).
Hi @LeoChen ,
How certain are you that the property value in Composer is the same as the one in the OPC Client?
I am asking this because Composer only gets the VTQ (which includes the Quality that derives the thumbs up/down) when you click the the Properties tab or when you click the Refresh button.
There's a service called GetPropertyValuesVTQ (or GetPropertyTime if you want to be specific) - execute that and compare the property timestamp with the one from the OPC Client. If indeed the timestamps are the same, the question is valid (not that I can answer why).
But still, we would need to know this first.
they are sure the same one on thingworx and modbus server of kepware, because this tag is setted up by myself.
the result of excuting GetPropertyValuesVTQ is as fellows:
Is there any misconfiguration on thingworx? Configurations on thingworx are as fellows:
Thank you very much.
Hi @LeoChen ,
I tried to change the startType, new error occurred. So I feedback to PTC.
Thank you for your reply.
