Providing a pop up message on click of button.
svisveswaraiya
I wanted to give a popup message on clicking a button.I dont want to give it using navigation button.
Instance: I am using a save button which saves the report.Here,
On clicking the save button i wanted to display a pop up which says "saved successfully".
How can I make it possible?
V.Shalini.
4 REPLIES 4
1. Go to the properties under your Thing ( the one that you are pulling services from).
1.a. Select your Service
1.b. band your button/widget's  property 'Click' to the service
2. Click into your service >'Configure the Selected Entity'
3. Add the message you wanna display in case of a successful or failure case and select check box
4.Test your mashup. On the top of the screen, message should pop.
Hope this is what you are looking for.
There is a widget called Status Message, you can bind your button to the widget and you can get the popup.
In addition, if you have a validation service to check if your saving process is really successful, you can bind your service output to a Validation widget, and the equation inside will tell it's true or false, and the true event can be used to trigger the Status Message widget
Sugumar_5656
(To:zyuan1)
How to customize the status message popup window.
Status Message widget only pops up a TextBox, no extra decorations can be done;
If you want other information/ image in the popup , use Navigation widget instead.
