Purge Value Stream
dbologna1
Purge Value Stream
Hi All,
I need to purge the entire value stream bound to thing but I do not found the PurgeAllHistoryProperty service.
Where I can found this service?
Many Thanks
Dimitri
These purge services are not in old Thingworx versions, this is the screenshot of 7.3.2, they have it.
5 REPLIES 5
Hi Dimitri Bologna
The Service name is PurgeAllPropertyHistory.
To add here; we need to run PurgeAllPropertyHistory service from the Thing which implements Value Stream. Running it from the Value Stream entity is not the correct way.
Hi Ankit,
I'm Sorry, but in the list of services of Thing that implements the value stream there is not this service.
Like Purge exist only the PurgePropertyHistory.
have I need to install one exstension ?
Many Thanks
BR
Dimitri
Hi Ryan,
I used  the version 7.2.3 b 48. of Thingworx.
I will install the last version 7.4.
Many Thanks
BR
Dimitri
