Query related to widget property
SV_10230677
Is style theme part of widget property .?
I believe most of the widgets will have Style Theme property under Style Properties Tab.
5 REPLIES 5
does the style property comes under widget property .?
Yes, Style properties are property of Widget. Every widgets has it's own set.
jensc
(To:SV_10230677)
Just want to point out that the Grid widget for example, you need to first set the "UseTheme" property for the widget to use the style theme:
Seems like it otherwise uses the other styles in the style properties tab:
I have not seen any other widgets that do it this way though.
Jens
Hello @SV_10230677
Kindly accept the solution if your query has been answered for the benefit of other community members.
Do share if you have any further queries.
Regards
Bhawna
