does the style property comes under widget property .?
Yes, Style properties are property of Widget. Every widgets has it's own set.
Just want to point out that the Grid widget for example, you need to first set the "UseTheme" property for the widget to use the style theme:
Seems like it otherwise uses the other styles in the style properties tab:
I have not seen any other widgets that do it this way though.
Jens
Hello @SV_10230677
Kindly accept the solution if your query has been answered for the benefit of other community members.
Do share if you have any further queries.
Regards
Bhawna
