QueryPropertyHistory service no storing any data
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
I have a simple remote thing and 1 property which is logged and persist the data change is also set to value.
It is getting data from Kepware using industrial connection, on composer it is changing data but on QuryPropertyHistory no data is reflecting please check screenshot.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Installed a fresh new DB and it working fine now, I guess there was some issue in backed corruption of data.
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Do you see any error message related to remote thing in Application log?
Also check whether you have assigned ValueStream to remote thing
/VR
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
There are no errors in application logs and I have also attached VS to remote thing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Did you assign a value stream to the thing?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Yes I have assigned a value stream
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Sorry, missed that in your other reply. To isolate the problem: When you remove the binding and update the value manually, does it work then?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi ,
I removed the binding and manually changed the values still I am getting blank infotable in service
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
now add a new property, just logged, not persisted, no index, and try with that one. Also try restarting the platform, if possible.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I have created a new property with only log enabled, and also restarted tomcat. Still no result. PFA
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Ok last resort is to switch the thing to another VS. If that doesn't work, create a ticket with support.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I tried switching VS not helped, I have opened support ticket. Thanks for the help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Once this is resolved, please post the resolution here for everyone's learning.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Yeah Sure
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Yes I have restarted Platform and DB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
I noticed a strange thing QueryPropertyHistory is working when I change property data type to String.
PFA
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thanks.
