Querying Infotable?
tyadav
Querying Infotable?
I am trying to create some custom queries in order to display results of the thing's properties. I am following the format mentioned in another thread here as How to query form infotable using query function?
Like that thread I also want to execute similar sort of thing where Speed >'20' and id=1.
However, when executing the service, I get the error as Wrapped java.lang.NullPointerException Cause: null.
    var query = {
    "filters": {
    "type": "AND",
    "filters": [
        "fieldName": "Speed",
        "type": "GT",
        "value": "20"
        "fieldName": "ID",
        "type": "EQ",
        "value": "1"
var params = {
t: result /* INFOTABLE */,
query: query
var result = Resources["InfoTableFunctions"].Query(params);
Please do let me know what may have been the error in the code/process and what could be the possible solution?
Thanks!
P.S. I am keeping the output of the service as InfoTable
15 REPLIES 15
For id=1 it's "EQ" condition not "LT"
tyadav
(To:CarlesColl)
That was a typo here in the question (I corrected it now). I corrected it and tried it but the same error is displayed again.
I'm not sure if that's the reason, but try values without " as it are Number/Integer values
Also check if ti's Case Sensitive, on the where condition sample you wrote id and on the Query you wrote ID
tyadav
(To:CarlesColl)
I have inserted the code through the snippets and hence the values of the fieldname are directly taken from the name of the properties.  The example which I gave in my question statement was written just to introduce the problem.
I have also tried querying with just one fieldname but it throws the same error.
And which it's the content of the parameter t: result ( I mean previous result value )
tyadav
(To:CarlesColl)
This t:result , I am not sure what exactly it does, since I am just checking out the functionality by using the code provided in the thread How to query form infotable using query function?
That's the problem, input value t it's the table that you want to filter with the Query, if result it's null that's the reason that it fails.
tyadav
(To:CarlesColl)
OK, I understand. Can you maybe suggest a correct syntax for the code?
The code it's correct, the problem it's that you don't have an input Table where to query.
tyadav
(To:CarlesColl)
Ok, so my properties are stored in Value Streams, does this functionality work with those?
Any infotable content ( Stream, Value Stream, Infotable Property,...)
tyadav
(To:CarlesColl)
Ok, so I have a value stream VS1 containing the properties which I want to query. So what should be the syntax to include that in the code and make sure that it takes the values from VS1. I am a little new to this and hence some of my concepts may not be clear enough.
Thanks!
I think better you go through Training or documentation to learn about how data it's organized on TW and how to query it.
tyadav
(To:CarlesColl)
Hey,
Thanks for the quick response. I did try without " and with ' as well but nope, same error
