Hi All,
When I was using PostMan, I clicked the Send button and nothing happened,The system prompts as follows:you don't have permission to send requests in this workspace. How should I solve this problem?
Did you use right pair of headers for app-key?
Regards
Shyam
In fact, I am a beginner and I don't know how to set configuration for Postman. Could you please explain in detail how to set authorization for the postman?
I have set up app-key in ThingWorx, but I don't know which authorization should be used.
Follow below links
https://www.ptc.com/en/support/article/CS224211
or this
https://developer.thingworx.com/resources/guides/thingworx-rest-api-quickstart
Regards
Shyam
Hi @ZL_9884170.
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question.
--Sharon
