I'm reading the article https://www.ptc.com/en/support/article/CS204091?&posno=1&q=204091&ProductFamily=ThingWorx&source=search , but feel a little bit confused about the phrase "Why is there a performance hit at 100,000 records?" .
The phrase has two statements:
#1 said it's NOT a huge performance hit as the initial query based on the timestamp returns the subset of time,
but #2 said it's a performance hit because initial pull returns entire stream instead of subset even if the query based on default timestamp.
So, is it a performance hit or not for the query on stream based on default timestamp ?
Sean
Hi Sean,
If you query by the default timestamp field there isn't "any" performance hit, at least with PostgreSQL, as it's indexed by this field and only returns the desired data.
Carles.
Hi Sean,
Carles.
Yes, I have the same understanding with you . that's why I feel the article is a little bit contradictory between #1 and #2. If thingworx does use the indexed default timestamp field instead of loading the whole stream entries, then it should not be limited by 100,000 records. Thank you .
Sean
Yup, I have millions rows on Streams and ValuStreams, no issues if you use timestamp query.
Hi @seanccc.
If you feel an article is misleading or incomplete, please feel free to submit your feedback via the button as seen in the screenshot below. Please provide specifics on the information in question so our engineers can re-evaluate the content.
Regards.
--Sharon
Hi @seanccc.
Aside from any article updates, if you feel your question has been answered, please mark the appropriate reply as the Accepted Solution for the benefit of others with the same question.
Thank you for your participation in our community!
Regards.
--Sharon
