RadioButton SelectedValue not set to default value at Mashup load
SOLVED
Re: RadioButton SelectedValue not set to default value at Mashup load
Thanks for looking into it :)
This is making the widget harder to use, but if this works as designed.. ;) Not sure if this "undefined" behavior is useful in any case.
