Read data from SQL database a write to KepserverEx via ThingWorx
SOLVED
Regular Member
Hi all,
i am new in thingworx. I would like to read data from SQL db and write to OPC via THX. Could you, please, help how?
I connect successfully OPC to TWX
I try connect MS SQL 2014 to THX via Relational DB extension, but I have some troubles - Unable to Invoke Service test on SQL : null
JDBC Driver Class Name com.microsoft.sqlserver.jdbc.SQLServerDriver
jdbc:sqlserver://localhost:8080;databaseName=thingworx
Error Getting Tables : The TCP/IP connection to the host localhost, port 8080 has failed. Error: "The driver received an unexpected pre-login response. Verify the connection properties and check that an instance of SQL Server is running on the host and accepting TCP/IP connections at the port. This driver can be used only with SQL Server 2000 or later."
If I try port 1433: firewall is off
Error Getting Tables : The TCP/IP connection to the host localhost, port 1433 has failed. Error: "Connection refused: connect. Verify the connection properties. Make sure that an instance of SQL Server is running on the host and accepting TCP/IP connections at the port. Make sure that TCP connections to the port are not blocked by a firewall."
Could you please help with SQL connection to THX and how to send data to OPC from SQL via THX ?
Gracias
Re: Read data from SQL database a write to KepserverEx via ThingWorx
The issue with SQL connection solved. Issue was in the connection string... instead of "localhost" I used exact PC´s name Now I need to solve how to automatically read data from MSSQL and write to OPC and VV. Thanks
Are you sure that MS Server is listening to port 1433 ? Can you access it from an other JDBC based application (e.g. DbVisualizer).
Using Sql Server Configuration manager > Sql Server Network configuration, verify that TPC/IP is enabled. Also review the TCP/IP properties in there, see https://kb.sos-berlin.com/pages/viewpage.action?pageId=17499564 for example
Hi @juniorI4.
Since you found and posted the solution to the problem, please mark your last response as the Accepted Solution for the benefit of others with the same question.
--Sharon
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
