Redirect login to FormLogin
SOLVED
Re: Redirect login to FormLogin
Here is the code of the Authenticator.
Basically, whenever you are pressing the Login button in the browser, It will execute the Method Authenticate.
In there, you basically implement your logic to authenticate. In this code, if either the user or the password is empty, it throws an error. In the Catch block, it's setting redirect to true and setRequiresChallenge to true (which will execute the method IssueAuthenticationChallenge). In that method, if redirect is true, then it redirects the user to formLogin....
If the user is good then continue to the home mashup set in the organization.
import java.io.IOException;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import com.thingworx.common.SharedConstants;
import com.thingworx.security.authentication.AuthenticationUtilities;
import com.thingworx.security.authentication.AuthenticatorException;
import com.thingworx.security.authentication.CustomAuthenticator;
import ch.qos.logback.classic.Logger;
public class LoginAuthenticator extends CustomAuthenticator {
    private String user;
    private String requestUrl;
    private String password;
    private boolean isFormLogin;
    private boolean isRedirect;
public LoginAuthenticator() {
        user = null;
        requestUrl = null;
        password = null;
        isFormLogin = true;
        isRedirect = false;
@Override
    public boolean matchesAuthRequest(HttpServletRequest httpRequest)
            throws AuthenticatorException
            requestUrl = httpRequest.getRequestURL().toString();
            if((!requestUrl.contains("action-login")) & (!requestUrl.contains("FormLogin")))
                isFormLogin = false;
                isRedirect = true;
                setRequiresChallenge(true);
            } else
            if(requestUrl.contains("action-login"))
                user = httpRequest.getParameter("thingworx-form-userid");
                password = httpRequest.getParameter("thingworx-form-password");
            return true;
@Override
   public void authenticate(HttpServletRequest httpRequest, HttpServletResponse httpResponse)
        try {
if(user.isEmpty() || password.isEmpty()){
getApplicationLogger().error("The username or password is empty");
throw(new AuthenticatorException("The username or password is empty"));
AuthenticationUtilities.validateCredentials(user, password);
            setCredentials(user, password);
AuthenticationUtilities.getSecurityMonitorThing().fireSuccessfulLoginEvent("<a valid account with rights to the Mashup>", SharedConstants.EMPTY_STRING);
} catch (Exception e) {
// TODO Auto-generated catch block
isRedirect = true;
super.setRequiresChallenge(true);
e.printStackTrace();
@Override
   public void issueAuthenticationChallenge(HttpServletRequest httpRequest, HttpServletResponse httpResponse)
        if(isRedirect)
            String urlString = "/Thingworx/FormLogin/Everyone";//replace with your own organization
            try
                httpResponse.sendRedirect(urlString);
            catch(IOException e)
