Regarding Color in Mashup
DMu3
Can anyone tell how to set black theme in mashup.  I attached my screenshot below.. In that I created mashup, i used tabs, i set black color to flex container area. But, in between tabs white color are appeared.  I need to set it as black color.
1 ACCEPTED SOLUTION
raluca_edu
(To:DMu3)
Try the attached theme,add it to your mashup,  hope it is what you are looking for.
Raluca Edu
2 REPLIES 2
raluca_edu
(To:DMu3)
Raluca Edu
DMu3
(To:raluca_edu)
Thank you so much it is working now.
