Can anyone tell how to set black theme in mashup. I attached my screenshot below.. In that I created mashup, i used tabs, i set black color to flex container area. But, in between tabs white color are appeared. I need to set it as black color.
Try the attached theme,add it to your mashup, hope it is what you are looking for.
Raluca Edu
Raluca Edu
Thank you so much it is working now.
