Regarding Directory Services
tayyasamy
I am trying to configure Directory Services in Thingworx and AD service in AWS EC2. Even, thingworx is running in the same server but i am getting error like,
'Authentication attempt #1 FAILED for [user = Administrator]: Invalid Password".
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<Entities build="33" majorVersion="5" minorVersion="0" revision="2" schemaVersion="773">
  <DirectoryServices>
  <DirectoryService className="com.thingworx.security.directoryservices.LDAPDirectoryService" description="Wipro Flex Thingworx Directory Service" documentationContent="" enabled="false" homeMashup="" lastModifiedDate="2014-08-20T17:20:39.620-04:00" name="WiproFlex" priority="1" tags="">
  <Owner name="Administrator" type="User"/>
  <avatar/>
  <DesignTimePermissions>
  <Create/>
  <Read/>
  <Update/>
  <Delete/>
  <Metadata/>
  </DesignTimePermissions>
  <RunTimePermissions/>
  <VisibilityPermissions>
  <Visibility/>
  </VisibilityPermissions>
  <ConfigurationTables>
  <ConfigurationTable description="LDAP Settings" isMultiRow="false" name="LDAPProxyConfiguration" ordinal="0">
  <DataShape>
  <FieldDefinitions>
  <FieldDefinition aspect.defaultValue="389" baseType="NUMBER" description="LDAP Server port" name="port" ordinal="0"/>
  <FieldDefinition aspect.defaultValue="uid=admin,ou=system" baseType="STRING" description="LDAP Distinguished Name to use when binding" name="adminBindDN" ordinal="0"/>
  <FieldDefinition baseType="PASSWORD" description="LDAP administrative password" name="adminPassword" ordinal="0"/>
  <FieldDefinition aspect.defaultValue="ou=people" baseType="STRING" description="User Base DN" name="userBaseDN" ordinal="0"/>
  <FieldDefinition aspect.defaultValue="localhost" baseType="STRING" description="LDAP Server" name="server" ordinal="0"/>
  <FieldDefinition aspect.defaultValue="uid" baseType="STRING" description="LDAP user id attribute to match when looking up a user" name="userIdAttribute" ordinal="0"/>
  </FieldDefinitions>
  </DataShape>
  <Rows>
  <Row>
  <port>389.0</port>
  <adminBindDN>
  <![CDATA[DC=AdminDC,CN=AdminCN]]>
  </adminBindDN>
  <adminPassword>
  <![CDATA[ugd08BRQrg5gmA1yOvImaw==]]>
  </adminPassword>
  <userBaseDN>
  <![CDATA[DC=UserDC]]>
  </userBaseDN>
  <server>
  <![CDATA[<Directory Server IP>]]>
  </server>
  <userIdAttribute>
  <![CDATA[User Name]]>
  </userIdAttribute>
  </Row>
  </Rows>
  </ConfigurationTable>
  </ConfigurationTables>
  <ConfigurationChanges/>
  </DirectoryService>
  </DirectoryServices>
</Entities>
Configuration File Attached.
PaiChung
22-Sapphire I
(To:tayyasamy)
The message seems to say that the User name / Password you provided is incorrect.
You are pointing to a 'node' in AD and are using a permitted User/pwd within that node and its children correct?
ttielebein
(To:tayyasamy)
Are you sure there are no special characters in the password which LDAP can't handle? For instance, colons almost always cause issues.
