Regarding Directory Services
Newbie
I am trying to configure Directory Services in Thingworx and AD service in AWS EC2. Even, thingworx is running in the same server but i am getting error like,
'Authentication attempt #1 FAILED for [user = Administrator]: Invalid Password".
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<Entities build="33" majorVersion="5" minorVersion="0" revision="2" schemaVersion="773">
  <DirectoryServices>
  <DirectoryService className="com.thingworx.security.directoryservices.LDAPDirectoryService" description="Wipro Flex Thingworx Directory Service" documentationContent="" enabled="false" homeMashup="" lastModifiedDate="2014-08-20T17:20:39.620-04:00" name="WiproFlex" priority="1" tags="">
  <Owner name="Administrator" type="User"/>
  <avatar/>
  <DesignTimePermissions>
  <Create/>
  <Read/>
  <Update/>
  <Delete/>
  <Metadata/>
  </DesignTimePermissions>
  <RunTimePermissions/>
  <VisibilityPermissions>
  <Visibility/>
  </VisibilityPermissions>
  <ConfigurationTables>
  <ConfigurationTable description="LDAP Settings" isMultiRow="false" name="LDAPProxyConfiguration" ordinal="0">
  <DataShape>
  <FieldDefinitions>
  <FieldDefinition aspect.defaultValue="389" baseType="NUMBER" description="LDAP Server port" name="port" ordinal="0"/>
  <FieldDefinition aspect.defaultValue="uid=admin,ou=system" baseType="STRING" description="LDAP Distinguished Name to use when binding" name="adminBindDN" ordinal="0"/>
  <FieldDefinition baseType="PASSWORD" description="LDAP administrative password" name="adminPassword" ordinal="0"/>
  <FieldDefinition aspect.defaultValue="ou=people" baseType="STRING" description="User Base DN" name="userBaseDN" ordinal="0"/>
  <FieldDefinition aspect.defaultValue="localhost" baseType="STRING" description="LDAP Server" name="server" ordinal="0"/>
  <FieldDefinition aspect.defaultValue="uid" baseType="STRING" description="LDAP user id attribute to match when looking up a user" name="userIdAttribute" ordinal="0"/>
  </FieldDefinitions>
  </DataShape>
  <Rows>
  <Row>
  <port>389.0</port>
  <adminBindDN>
  <![CDATA[DC=AdminDC,CN=AdminCN]]>
  </adminBindDN>
  <adminPassword>
  <![CDATA[ugd08BRQrg5gmA1yOvImaw==]]>
  </adminPassword>
  <userBaseDN>
  <![CDATA[DC=UserDC]]>
  </userBaseDN>
  <server>
  <![CDATA[<Directory Server IP>]]>
  </server>
  <userIdAttribute>
  <![CDATA[User Name]]>
  </userIdAttribute>
  </Row>
  </Rows>
  </ConfigurationTable>
  </ConfigurationTables>
  <ConfigurationChanges/>
  </DirectoryService>
  </DirectoryServices>
</Entities>
Configuration File Attached.
2 REPLIES 2
Highlighted
Re: Regarding Directory Services
The message seems to say that the User name / Password you provided is incorrect.
You are pointing to a 'node' in AD and are using a permitted User/pwd within that node and its children correct?
Highlighted
Are you sure there are no special characters in the password which LDAP can't handle? For instance, colons almost always cause issues.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
