Hi team,
In 8.4 I can see session variable LastAssetChange while creating a mashup. But in 8.5, It is not present. Can someone please let me know where can I find these and what is the specific use of this LastAssetChange variable.
Thanks and Regards,
Look in the UserManagementSubsystem configuration and check if the UserSessionShapes match between your 8.4 and 8.5 environments. If not, you can add them to that list.
Hello @Bhanu_Manoj,
Can you please provide more details or a screenshot with the session variable in ThingWorx 8.4 ?
Thank you,
Screenshot in 8.4
in 8.5 we can see only as below.
Thanks, I found the necessary shapes in UserManagementSubsystem.
