Hi All,
I have an infotable to store marks of students which has a field named "marks". Can I get the count of students who got 90,75, 35 etc.... Example 7 students scored 90, 3 students scored 50.
I need the percentage of students that scored particular mark. In above case 70 percent scored 90 marks, 30 percent scored 50 marks.
I am trying to use Donut chart to represent the percentage of occurance of each mark.
Thanks and Regards,
Bhanu.
The chart you are looking for does not appear to be available as an out of the box choice. I did some searching and did find something that might meet your needs.
Pie Chart to Donut Chart and add boundary to the bar chart , this is a custom widget.
Good Luck
Peter
Good Luck
Peter
