Hi All,
Can someone please help me with the syntax of filter row by value functionality on an infotable. When I checked in snippets it shows .Find(yourRowValueObjectHere). I might be checking in a wrong way.
Please help.
Thanks and Regards
For "raw" find on infotable, you can put just Infotable columns and values passing as JSON. Something like:
myInfotable.Find({ columnName1: columnValue1, columnName2: columnValue2 });
And it returns the row with exact matching of both column values or null.
Thanks a lot Carles. It worked fine.
