Hello everybody,
i combined several widgets to one gadget which i am using within a mashup.
When using mashups there is a plus sign in the upper left corner which indicates to create a dashboard. I want to remove it/ making it unvisible. I did that once before but cannot remember how i did it. The property within the gadget are the same for the gadget where it is working and the gadget where it is not. In the image below you can hopefully see what i mean.
You may try disable this in the dashboard, or simply change the [Style with + sign] directly.to another symbol
I dont have this option in the property window of the gadget. I am not using Dashboard widget. I use widgets in a mashup (gadget). See pichture below.
Hi, the gadget widget has been removed and it cannot be found in 8.4, 8.5, 9.0 versions, which version are you using?
