I created a repeater contained in a normal mashup allowing users to configure different displayed parameter values. There can be anywhere from 0 to 100+ repeater rows available. The issue I am having is that I call my service once to populate all of the rows in my repeater which works fine. However, as soon as I start scrolling through the rows the repeater widget keeps flashing while the new rows are being displayed. Once the scrolling stops the flashing goes away. This doesn't make for a really smooth and user friendly experience. Is there a way to prevent the flashing once the scrolling starts in a repeater?
I would like my repeater to function more like a grid that scrolls.
Paul
Did you try the different LOAD behaviors? Sounds like you have it on Load/Unload right now, I would recommend to completely avoid flashing to use Load All. and to minimize it Load/No Unload
Thanks Pai!
That fixed the issue. It is now working exactly as I had hoped it would.
