When I try to give repeater selected style,I am getting color only at left edge.I need color for the entire tile.Could someone help me?
Try the following CSS:
.repeater-item-selected
border: 4px red solid !important;
This will add red border for selected items in the repeater.
Hope it helps,
Raluca Edu
For the selection, you can easily create a custom style to just get a border around your cell by creating a new style with blanks for all colors except 'Line Color'.
Please see this post:
https://community.ptc.com/t5/ThingWorx-Developers/Styling-selected-rows-in-a-Repeater/m-p/527889
Note: Repeater widget is deprecated, in ThingWorx 8.2 and later, the Collection Widget is available. The Collection Widget contains all the functionality available in the Repeater Widget, with additional performance and functionality options. It is recommended that you use the Collection Widget if you are using ThingWorx 8.2 or later.
Hope it helps,
Raluca Edu
I tried giving only line color,but it is not showing any border color.Could you please recheck?
Hope it helps,
Raluca Edu
