Resizing the Trigger Icon in Dynamic Panel Widget
Nate_145
7-Bedrock
I'm looking to develop a mashup for mobile use that takes advantage of the dynamic panel widget. However, the trigger button/ icon is extremely small when used in that setting. Is there a way to enlarge the icon?
PaiChung
22-Sapphire I
(To:Nate_145)
I could be wrong, but I thought you could provide custom icons for that.
3 REPLIES 3
PaiChung
22-Sapphire I
(To:Nate_145)
@PaiChung How to add custom icons to the Dynamic Panel trigger button?
If there is a way to do that while making that icon bigger than the default button then yes. If a custom icon ends up the same size as what the default is then it doesn't do a ton of good.
I've subverted this issue on my end by tying the expand/ collapse action to a button widget on each part of the panel that collapses/ expands to view the other panel. I then set the panels to only display at 100% minimum to take up the whole screen.
