Responsive screen
ppradhan-2
Responsive screen
     i have developed multiple mashups but seen that when i try to access the same mashup url in different resolution system it gives scroll bars, cant just mashup adjust itself to the respective screen?
ex. if i make any mashup in desktop it seems perfect but try to open it in laptop then gives scroll bars and looks messed up.
is there any way ? or i need to make mashups for the laptops directly?
Pravin Pradhan
6 REPLIES 6
supandey
(To:ppradhan-2)
Hi Pravin, are you creating responsive mashups? Would it be possible to share an e.g. screenshot of one of your mashup to get a clear idea?
sure sushant,
I am creating responsive mashup.
you can see 1st image is from desktop and other from laptop with different resolution, giving the scroll bar.
Hi pravin pradhan​,
It seems that you are using tab widget in your Mashup. Is it Responsive Tab widget? If No try using responsive one.
Ankit Gupta
yah i am using tab widget but it is same with all other simple mashups also.
pravin pradhan​, Please try using Responsive Tab widget and see if it helps.
its not just for tabs but same for mashup.
i am wishing that mashup should adjust according to screen and scroll bar should not be there on both sides. is it possible?
above image is from desktop and below from laptop.
