i have developed multiple mashups but seen that when i try to access the same mashup url in different resolution system it gives scroll bars, cant just mashup adjust itself to the respective screen?
ex. if i make any mashup in desktop it seems perfect but try to open it in laptop then gives scroll bars and looks messed up.
is there any way ? or i need to make mashups for the laptops directly?
Pravin Pradhan
Hi Pravin, are you creating responsive mashups? Would it be possible to share an e.g. screenshot of one of your mashup to get a clear idea?
sure sushant,
I am creating responsive mashup.
you can see 1st image is from desktop and other from laptop with different resolution, giving the scroll bar.
Hi pravin pradhan,
It seems that you are using tab widget in your Mashup. Is it Responsive Tab widget? If No try using responsive one.
Ankit Gupta
yah i am using tab widget but it is same with all other simple mashups also.
its not just for tabs but same for mashup.
i am wishing that mashup should adjust according to screen and scroll bar should not be there on both sides. is it possible?
just take a look at mashups
above image is from desktop and below from laptop.
