Responsiveness of the Containers
BP_10210965
3-Visitor
Is it possible to make the containers more responsive, such that, if a graph above and/or beside is blank, then it should be able to fill in that position, thereby not leaving a blank space and making the mashup look better than to have a weird blank space beside and/or below/above it. imagine, you have used 4 graphs in a mashup, but only the left top and the right Bottom has data. we can simply just make the two data filled graphs cover the area rather than having 2 massive blanks, which will be very bland at a UI/UX perspective
TonyZhang
(To:BP_10210965)
Hi @BP_10210965,
I think there's no OOTB function that can achieve this.
Please submit your idea in https://community.ptc.com/t5/ThingWorx-Ideas/idb-p/thingworxideas
As a workaround, you can try writing a custom service to check whether your graph contains data or not.
If not, set the respective graph's container's CustomClass to "empty" for example.
Then in the CustomCSS, apply below code:
.empty {
      display: none;
TonyZhang
(To:BP_10210965)
Hi @BP_10210965,
.empty {
      display: none;
