I'm writing a service where I need to exit/return execution based on a programmatic decision. For example:
if (var < 10)
return/exit
continue execution
Thingworx throws an error when saving a service if you put "return" in the code. What's the proper way to exit a service in the middle of execution?
Thank you,
Nick
There's no way of doing it, you need to put on if/else conditions.
For some special cases I use a "fake" throw exception:
throw "MESSAGE";
But I don't recommend you on using it, as it generates nasty logger messages, it would be good that they implement a way of doing both:
Carles.
I usually handle this by doing everything that I want to do in the if. So if the condition is not met, the service simply doesn't do anything and the call ends.
In your situation I would use
if ( var > 10 )
// implement your code here
I also usually return some error messages if I need to show UI feedback, when the condition is not met. For example when I need to validate if all required fields have been inputted in a form created with ThingWorx.
Hope this helps,
Veronica
Also consider try/catch/throw (besides if/else)
wrap the service body in an immediately invoked function.
original:
do stuff
if (my_var < 10)
return; // fails
continue execution
wrapped:
var result = (function() {
do stuff
if(my_var < 10)
return; // works now.
continue execution
Great, thank you, everyone.
Nick
I've discovered another way with javascript of doing it:
labelName:
// -- your code
break labelName; // -- it will jump until the end of the brakets.
// -- other conditional code
Best Regards,
Carles.
