ThingWorx has the ability to run in a docker container on the newer versions. Is that something that is meant to just run at a developer level, or is it something that could be deployed on a production level.
Thank you!
Hi @MG_9567080.
Docker can certainly be deployed in your production environments and is a supported configuration. Be sure to check the prerequisites to ensure you are adhering to the supported versions.
Here is a link to the Help Center with details of setting up Docker in your environment.
Regards.
--Sharon
Hi @MG_9567080.
Regards.
--Sharon
