Hello everyone,
i created a thing with a subscription in it. The subscription is configured with the Event DataChange and it is thrown.
The Problem is, that in the script of the description in want to make a RESTFul API call with GET.
I have the following code into the script:
var params = { proxyScheme: undefined /* STRING */, headers: undefined /* JSON */, ignoreSSLErrors: true /* BOOLEAN */, useNTLM: false /* BOOLEAN */, workstation: undefined /* STRING */, useProxy: false /* BOOLEAN */, withCookies: undefined /* BOOLEAN */, proxyHost: undefined /* STRING */, url: 'http://localhost:5000' /* STRING */, timeout: undefined /* NUMBER */, appendHeader: undefined /* BOOLEAN */, proxyPort: undefined /* INTEGER */, password: undefined /* STRING */, domain: undefined /* STRING */, username: undefined /* STRING */ }; // result: JSON var result = Resources["ContentLoaderFunctions"].GetJSON(params); logger.warn(result); logger.warn(result.W1); logger.warn(me.ktid.ktid); me.coolerValue1 = result.W1 + "/" + result.W2 + "/" + result.W3;
When the event is thrown i got the following error message in the logs:
User does not have visibility permission for ContentLoaderFunctions
AND (anonymous)
Execution error in service script [<THINGNAME>Event.DataChange:Property.ktid] : Wrapped java.lang.RuntimeException: Entity [ContentLoaderFunctions] does not exist Cause: Entity [ContentLoaderFunctions] does not exist
What permissions are left here?
Thanks in advance
Hannes
Add visibility and runtime permission to "Resources" to the user/organization on "SYSTEM" category. This may be the issue.
Hey, thanks for the fast response. Thats it! It worked when i added visbility and runtime permissions to the resource "ContentLoaderFunctions".
Thanks a lot!
