Hi All,
how to configure Adapter Settings in Ping?
What can be the Instance Name and ID here?
Janakiraman P
Hi @tdixit
Thanks for the guidance.
Now I stuck at
Is this Endpoint URL should be provided by IDP?
Janakiraman P
Hello @Janakiraman-P
Please check this link as well as this community post and see if it helps you to configure ping Federate
Toolika Dixit
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question
Toolika Dixit
