SP: Thingworx SSO with Ping as CAS
Janakiraman-P
Hi All,
how to configure Adapter Settings in Ping?
What can be the Instance Name and ID here?
Janakiraman P
tdixit
(To:Janakiraman-P)
Hi @Janakiraman-P
Thank you for reaching out to PTC
Please check this link  and see if it helps
Toolika Dixit
tdixit
(To:Janakiraman-P)
Hi @Janakiraman-P
Toolika Dixit
Janakiraman-P
(To:tdixit)
Hi @tdixit
Thanks for the guidance.
Now I stuck at
Please provide the remote party URLs that you will use to resolve/translate the artifact and get the actual protocol message.
Is this Endpoint URL should be provided by IDP?
Janakiraman P
tdixit
(To:Janakiraman-P)
Hello @Janakiraman-P
Please check this link as well as this  community post  and see if it helps you to configure ping Federate
Toolika Dixit
tdixit
(To:tdixit)
Hi @Janakiraman-P
If you feel your question has been answered, please mark the appropriate response as the Accepted Solution for the benefit of others with the same question
Toolika Dixit
